EDIT CYCLE
EDIT CYCLE
Message 1 of 8
EDIT CYCLE
   I need to edit cycle.How can I do that.I know if I want to change it I have to change many line.
 Please make an example just for one cycle.
THANKS
Replies (7)
Message 2 of 8
Laurens-3DTechDraw
THANKS
We can't make a example if we have no idea what you are trying to change.
So if you give a little more info we can help you better.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 8
My controller is 840C (1994). I need to change cycle . for example in 840D cycles form are CYCLE83(A,B,C,D,E,G) and ... . in 840C they are R21=   R22=  R23=  and .... .
how can I change them.
Message 4 of 8
Laurens-3DTechDraw
Did you know there is a special 840C post?
You can find it here: http://cam.autodesk.com/posts/?p=siemens-840c
Laurens Wijnschenk
3DTechDraw
Message 5 of 8
Yes i know but that is for milling machine
I need for lathe machine.
My lathe has 3axis x y z and live tool c axis.
I love autodesk softwares i worked with them for 20 years. Also i work with powermill and in powermill i can made any post for milling machine. On turning strategy in powermill i cant make treads.
Best , simple and powerful software for me is inventor hsm.
Unfortunately i live in iran. In iran we dont have any agencies for your product.
Please tell me how can i do that.
Thanks for your helps.
Sent from my iPhone
Message 6 of 8
Laurens-3DTechDraw
The cycles in the 840C post should be very close to what you need in the turning post.
Usually they can be copied for 90%.
All the cycles live in the onCycle Function.
Laurens Wijnschenk
3DTechDraw
Message 7 of 8
Thanks.
I will test it.
Sent from my iPhone
Message 8 of 8
Thanks dude
It is exactly that i want
I know change the cycle is difficult
Would you please tell me how can i do that.
Which lines i have to replace with other post
I want to change those cycle (in 840c) with turn mill post.
Thanks.
