I'm using a modified verison of the Fanuc post processor in Fusion360. I'm trying to create a drop-down menu in the property section of the post processor.
I know it's possible to create a true/false option, but I want several choices in the same menu. I want it to work exactly as the "built in" option "highFeedMapping". Sadly the code for "built in" options are not presented in the post processor code.
Example:
Text in description: "Stock material mounted in/at: "
Alternatives in drop down menu:
*vise
*table
*indexer
Then the post processor will adjust the result (like woorking coordinate system etc.), depending on the choice.
I can solve this by making the option "stock material mounted in/at: (1=vise 2=table 3=indexer)" and then just input a number. I don't think this is a good solution, but I can live with that if it's complicated to make the other solution.
Is it possible to create this menu in Fusion 360 and how do I do it?
Hi
I don't know about Fusion but in Inventor HSM express it's not possible.
The easiest solution is the one your proposed (1=.. 2=... 3=..)
The hardest solution is to make an "interactive" post (see interactive.cps in the post d/l section)
Thank you for the answer.
The interactive post processor seems like a good solution. The problem is that I can't get it to work, nothing happens when I try to post process the file. Maybee the program does not find the HTA-file?
I would really appreciate any tips to get it working. Has someone got it to work with Fusion 360?
