DN Solutions post tool offset issue
wheezy11
Message 1 of 1
wheezy11
 I've got 2 different Doosan/DN solutions Lynx 2100 series lathes. One is from pre name change and is labeled a Doosan, the other is the new DN solutions. With some parts, we use a boring bar with inserts for both drilling and boring, and just use different tool offsets for them, so a 01001 and an 01101 or something like that. When posting for the older machine using the Doosan labeled post, it does post out correctly. It warns me that I have two different tool types on the same turret number, but it works. When I post on the newer DN solutions post, it doesn't post the different diameter offset. It still tries to put in a tool change, but they both use the default 01001, even though the tool specifically calls out something else.
 1. Am I just missing a setting? I've checked my post processor options and can't find anything off. I'm using extended tool offsets on both machines, that's the only major thing I needed to touch previously.
 2. If I'm not missing a setting, other than my current solution of just manually editing the program every time, is there something I could add to the post simply to make this work? The most I've done is adding a snippet to posts copied from the forums to allow passthrough code from within fusion.
 3. If neither of those, is this forum where I would request a correction, would I do that in the HSM Post Processor ideas forum, or do I reach out to DN/Doosan via a contact or through my vendor or something to have that put in a queue to be addressed?
Replies (0)
