DMS 5-Axis Post Processor
Message 1 of 1
Revisiting this from awhile back,
a little info about the machine: 5-Axis DMS Router, Head/Head 4th-5th axis.  B-axis rotates over y-axis, and C-axis rotates around the Z-axis.
Fusion 360 CAM
Problem:
The post is outputting the orientation of the WCS relative to the orientation of the C-Axis.
  • Example:  when C-Axis is rotated 90 degrees, it appears the WCS will also rotate 90 degrees.  I've attached a ScreenCast(https://autode.sk/2O40ySm) of the setup, post options and post processor output.
.cps file attached.
I was having issues with orientation of the C-Axis and B-Axis relative to machine parameters, I believe that issue has been fixed, however, I do not know where/what to modify to lock in the WCS reference orientation during the rotation of the 4th and 5th axis.
Replies (0)
