Announcements
DMG NHX Celos only output H01
area419jon
area419jon
Id like to adjust my DMG NHX with Celos post to only output H01 instead of the specific tool number.  This has to do with the way the Mapps 5 control handles tool management on this machine, it only wants to see H01 instead of say H25.  I changed all my tools to have H1, but I keep getting nearly bitten by this if I copy/paste a toolpath from something else and its using the wrong tool.
Thank you
andrea.amilo
Hello @area419jon ,
the variable managing the Tool Length Offset is called 'lengthOffset'.
It is used at line 1458 and at line 1466 of the original DMG Mori NHX postprocessor, has shown here :
I think you can replace 'lengthOffset' with 1. This has to done on both lines:
hFormat.format(1)
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
area419jon
Worked perfect, thank you!
While I have you in here.  On the CMX Fanuc post, how would I change the end home position to G30 instead of G28?
andrea.amilo
Hello @area419jon ,
the postprocessor available on the postprocessor library has a user property named 'Safe Retracts'.
This allows you to choose between G28 and G30.
You can see below this choice in the 2 available postprocessor windows:
Please let me know.
Andrea Amilo
