Disable Coolant does not work on Tormach post
Eli_Dexter
Message 1 of 10
Eli_Dexter
In the operation under tool I have selected disable coolant. But, the G-code is still show M8 at the beginning of every operation.
Changing Coolant to Flood or Mist does change the code to M8/M7 as appropriate. But disable coolant does not have any affect.
Seems like a bug...
Replies (9)
Message 2 of 10
ivan.stanojevic
@Eli_Dexter
Open your postprocessor and search for setCoolant function.
You should be able to find these blocks of code:
 // Smart coolant is not enabled
  if (!properties.smartCoolEquipped) {
    previousCoolantMode = 8;
    coolCodes[0] = mFormat.format(previousCoolantMode);
	if (coolant != COOLANT_FLOOD) {
      warning(localize("Unsupported coolant setting. Defaulting to FLOOD"));
try with changing it to this:
	  if (tool.coolant == 0){
	  else{
Ivan Stanojevic
Message 3 of 10
Eli_Dexter
Did it and it did not help. Still getting "N70 S7500 M3 M8" code...
Tried adding the following:
previousCoolantMode = 9;
and
previousCoolantMode = 0;
Nothing help. still getting the same output with M8.
Message 4 of 10
ivan.stanojevic
I just tested it with the changes that I provided and it is working.
What software are you using?
Ivan Stanojevic
Message 5 of 10
Eli_Dexter
HSM Express running on the SolidWorks
Message 6 of 10
Eli_Dexter
Now it start working... I guess before all my changes to config file were not picked up by the HSM.
How to force HSM to reload new (updated) post configuration file?
Message 7 of 10
ivan.stanojevic
@Eli_Dexter
When you make changes to postprocessor, be sure that you save it. And when you are looking at the postprocessing window just hit F5 button to refresh it. HSM should be able to pick up the edited postprocessor file automatically.
Now that you have changed the generic postprocessor I advise you to save it to some other location rather than in the default post folder.
@AchimN
If you disable coolant in an operation using the generic Tormach post, it still outputs M8 code.
This should be fixed.
Ivan Stanojevic
Message 8 of 10
Eli_Dexter
I always work from my custom folder. In this way I have there only 2 posts (one for machine and one for setup sheet). When I need to switch it is much faster to find the post I am looking for...
I did not know about F5 referesh in the post screen.
Message 9 of 10
sharmstr
For those of you using SmartCool, you'll also have to change that block of code.
This really does need to be fixed in the default Tormach processor though.
Message 10 of 10
