Custom OSAI Post Processor
jta49
Message 1 of 9
jta49
I have a Hendrick Manufacturing HLD-L68 CNC router. I process all of my Gcode files using the OSAI post processor supplied by fusion, however my machine cannot read the G90, G91, and ho(x) codes. I am looking for a post processor that will not output these codes so I do not have to manually take them out myself. Any help is appreciated.
I have included two files to show what I take out each time, one is correct and one is the file with the invalid g90,g91 etc codes.
Thankyou,
James
Replies (8)
Message 2 of 9
Arun.rs
HI @jta49
 Thanks for raising your concern via Forum.
Open 'osai.cps' file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Go to line number 243, and remove ' gAbsIncModal.format(90' so final code will like below
 writeBlock(gFeedModeModal.format(94));
2. Go to line number 1170, change the below code
From this:
if (_useG28) {
      gAbsIncModal.reset();
      writeBlock(gMotionModal.format(0), gFormat.format(79), gAbsIncModal.format(91), words);
      writeBlock(gAbsIncModal.format(90));
To this:
if (_useG28) {
      writeBlock(gMotionModal.format(0), gFormat.format(79), words);
3.  To remove H offset , go to line number 544 and 551 and remove ' hFormat.format(lengthOffset)'
4. To give Y home position 100 in program end, go to line number 1140. Give 100 instead of 0 for '_yHome '
 _yHome = toPreciseUnit(100, MM);
Save the file and test the NC output carefully.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Message 3 of 9
jta49
Hey there, Thanks for the response and I really appreciate the help @Arun.rs . I have made the proper edits however when I try to import into fusion I am getting an "invalid post processor" error message. Any Idea what is going on?
Message 4 of 9
Arun.rs
Hi @jta49
Thanks for your feedback.
The error is because of a extra comma in line number 551 .
Remove the same and save the file.
Hope this helps!
Regards
Arun.RS
Message 5 of 9
jta49
I have edited it but now I am getting another random G90 code (see line 17 and line 106) along with a weird ending y value of 3.937 ? Any thoughts on how to fix that @Arun.rs ?
Message 6 of 9
jta49
Ah I realized for the Y-value at the end I am exporting in Inches and I assume it is converting to MM? That is why it is outputting the 3.9? @Arun.rs
Message 7 of 9
Arun.rs
Hi @jta49
Apologies for reply.
If your machine is not accepting G90 codes then you have to remove ' gAbsIncModal.format(90) ' from the post.
Use 'Ctrl+H' for replace .
Yes, the 3.9 is converting to inches .
Regards
Arun.RS
Message 8 of 9
jta49
Worked Perfectly! Thanks so much @Arun.rs
Message 9 of 9
jchaissonPWX3J
@Arun.rs ,
would you be willing to help me i have a very similar situation and I'm stuck. We are trying to switch from MasterCAM to InventorCAM. We have a C.R. ONSRUD 5-Axis Router thats uses an OSAI Controller and when i try and get C.R. ONSRUD to help im told they only can help and support MasterCAM Post Processors. When i compare NC files of  the same part i get similar G-Code formating but not exactly the same. please message me if you can help.
