CSV post processor for plasma cutting
kalunpaja
kalunpaja
Hello
I'm new with Fusion 360 and its cam features. All that I need to know is clear but I would like to know is it possible to get post processor for plasma cutting that creates .CSV files that contains only point coordinates, no G:s, no text, just coordinates? Other program that is use requires this type of file. Milling has this kind of post processor (Autodesk XY and XYZ) but these dont work with plasma cutting. Is there any other (easy) way to go aroud this than use milling function and pretend it is plasma cutting?
serge.quiblier
Hi @kalunpaja
you can do it yourself.
Copy the XYZ post, in a personal local or cloud folder, in the machine library, in Fusion360.
You will then have to edit the post.
Inside the post, in the starting lines (around line 25 in the copy of the latest version) search for this line:
capabilities = CAPABILITY_MILLING;
then change the line to the new one :
capabilities = CAPABILITY_MILLING | CAPABILITY_JET;
This will allow to use the post for milling and cutting.
Cheers.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
kalunpaja
That worked perfectly! Thank you so much👍
