Control Variable Thru Notes
sevenfive85
Message 1 of 14
sevenfive85
I would like to control the "R" value thru notes(see pic).
example: if i enter #1234 or any number in notes that line would spit out G90G10L12P1R#xxxx anything else it would default back to G90G10L12P1R0.  thank u
Accepted solutions (3)
Replies (13)
Message 2 of 14
makko74
hi,
i would it solve like this:
you need a global parameter in your post ( outside of an function ) e.g. var rValue = 0;
in the function  onParameter add the code:
case "notes":
    if (value != "") {
      if ( value.indexOf("#") > -1 ) {
        var test = value.split("\n");
        for ( var i=0; i<test.length; i++ ) {
          if ( test[i].indexOf("#") > -1 ) {
            try {
              rValue = getAsInt( test[i].split("#")[1].trim() );
            } catch(e) {
              rValue = 0;
            } finally {
              if ( rValue != 0 ) rValue = "#" + rValue;
            break;
    return;
and the last change the line ( from your pic 😞
writeBlock("G90G10L12P1R0");
in
writeBlock("G90G10L12P1R" + rValue);
rValue = 0;
/Mario
( beware not truly tested )
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
Message 3 of 14
makko74
P.S.
if you think it's too complicated to change here and there.
you can also simply substitute your line:
with
    var rValue = 0;
    if ( hasParameter("notes") ) {
      var notes = getParameter("notes");
      if (notes) {
        var test = notes.split("\n");
            try {
            } catch(e) {
              rValue = 0;
            } finally {
            break;
not tested
/Mario
Message 4 of 14
sevenfive85
YAY!!!!!! IT WORK... THANK YOU SO MUCH
Message 5 of 14
makko74
My pleasure.
/Mario
Message 6 of 14
sevenfive85
hi makk074 How can i limit the value to only positive integer and limit it to only 5 character long only? thx again
Message 7 of 14
makko74
change the finally block in
            } finally {
              if ( rValue < 0 || rValue > 99999 ) error("rValue out of range");
/Mario
Message 8 of 14
sevenfive85
Hello Makko74 or anyone who can help. what must I change to be able to use decimal points number rather than just integers?
Message 9 of 14
makko74
substitute getAsInt with getAsFloat should do the job
/Mario
Message 10 of 14
sevenfive85
THANK YOU makko74 It work but one more thing. How can i limit it to 4 decimal places only or round to 4 decimal places.  Also when i enter #1. in notes G90G10L12P1R1 appears, i would like it to show the decimal point too.    G90G10L12P1R1. (decimal point)
Message 11 of 14
sevenfive85
HI Makko74,
how can i modify the codes to do this?
example: if i enter #1234  in notes that line would spit out G90G10L12P1R#1234 and
               if i enter ##1234 it would spit out G90G10L12P1R1234(no # sign). thank you
Message 12 of 14
makko74
its much more easier if you use an other character as "#" for this.
maybe use a "!" ( stands for NOT in javascript )
#123  -> G...R#123
!#123 -> G...R123
    var rValue = 0;
      if (notes) {
          var posExc = -1,
              posNom = test[i].indexOf("#");
          if ( posNom > -1 ) {
            try {
              rValue = getAsFloat( test[i].split("#")[1].trim() );
            } catch(e) {
              rValue = 0;
            } finally {
              if ( posNom > 0 ) posExc = test[i].indexOf("!");
              if ( rValue != 0 ) {
                rValue = ( (posExc == ( posNom - 1 )) && ( posExc > -1 ) ) ? rValue : "#" + rValue;
            break;
NOT TESTED
/Mario
Message 13 of 14
makko74
if i remember me right then has Laurens answered a similar question from you here on this forum.
create a new format ( up in the post, if is there nothing similar in your post ) you also can look into the post-help file under createFormat
var rFormat = createFormat({decimals:4, forceDecimal:true});
and than change the line:
to
rValue = ( (posExc == ( posNom - 1 )) && ( posExc > -1 ) ) ? rFormat.format( rValue ) : "#" + rFormat.format( rValue );
ALSO NOT TESTED
/Mario
Message 14 of 14
sevenfive85
Hi All,
I am looking to pass some value inside notes between two characters "rotateDeg=xxxx". The '"rotateDeg=' would be the start of my character search and '"' would be my last character, I am looking for the value between these two (xxxx) to pass. I think the slice() method along with idexOf and lastIndexOf would need to be use but I am not sure what the syntax should look like. Using the code from above can someone please help me get the correct codes. thank you.
    var rValue = 0;
      if (notes) {
            try {
            } catch(e) {
              rValue = 0;
            } finally {
            break;
