Change X to Z axis
Change X to Z axis
emzy4k
Change X to Z axis
emzy4k
Hi guys, I am trying to modify Fanuc turning post processor for my mill, I'm using 4th axis as Lathe, and need to change axis ´´X´´ to ´´Z´´ and ´´Z´´ to ´´X´´ also ´´I´´ to ´´K´´ and ´´K´´ to ´´I´´´
When I'm changing output in variations...
var xOutput = createVariable({prefix:"Z"}, xFormat);
var zOutput = createVariable({prefix:"X"}, zFormat);
This does trick just for zOutput but xOutput stays X as this ( G0 X21.5 X5. )
Same for I and K, just K change and I stay...
Where I'm missing ??
boopathi.sivakumar
@emzy4k
Attach here the modified post and if possible could you please just attach the model file also
and the its better if you attached the modified nc also
File>Export>.F3d
and don't forgot to zip the file before attaching
Boopathi Sivakumar
Senior Technology Consultant
emzy4k
Hi and thank you for your interest to help me with it.
emzy4k
Thank you four your interest to help me 🙂
I couldn't attach files to the page so I'm trying by email
emzy4k
I found a solution,
there are other lines which needs to be changed...
// turning using front tool post
if (toolingData.toolPost == FRONT) {
xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1});
iFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1}); // radius mode
iOutput = createReferenceVariable({prefix:"K"}, iFormat);
// turning using rear tool post
} else {
xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:1});
iFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:1}); // radius mode
but I've got turning on mill 😄
