Its inside generic Fanuc milling post:
// user-defined properties
properties = {
writeMachine: true, // write machine
writeTools: true, // writes the tools
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
o8: false, // specifies 8-digit program number
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
allow3DArcs: false, // specifies that 3D circular arcs are allowed
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words
useParametricFeed: false, // specifies that feed should be output using Q values
showNotes: false, // specifies that operation notes should be output
useSmoothing: false, // specifies if smoothing should be used or not
usePitchForTapping: false, // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your CNC control must be setup for pitch mode!
useG95: false // use IPR/MPR instead of IPM/MPM
And then inside onCyclePoint
var F = cycle.feedrate;
if (properties.useG95) {
F = F/spindleSpeed;
var P = (cycle.dwell == 0) ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
Then look for properties.useG95 and copy and paste what you need from one to the other.
Andrew W. Software engineer (CAM Post Processors)
