Chamfer C-axis 810d mill-turn
uladzimiruser
Message 1 of 1
uladzimiruser
Hi.
Turning and milling machine 810d without Y-axis
I can not get the correct code when processing with the C-axis.
If the code is similar when using an axial tool, then when using a radial tool, the movement occurs along G0.
Camfer axial  11.mpfCamfer axial 11.mpfCamfer radial 12.mpfCamfer radial 12.mpf
This code is used when processing the axial tool.
N16 MSG ("; 2D-??????1")
N17 G17
N18 DIAMOF
N19 T3 D1
; champfer d10 axial
N20 SETMS(1)
N21 G97 S1=5000 M1=3
N22 G94
N23 G55
N25 G0 SPOS[4]=0.
N26 DIAMOF
N27 TRANSMIT
N29 M108
N30 G90 G0 Z15
N31 X-29.677 Y-12.926
N32 Z5
N33 G1 Z-21 F333.33
N34 X-29.67 Y-12.928 Z-21.121 F5000
N35 X-29.649 Y-12.933 Z-21.239
N36 X-29.614 Y-12.941 Z-21.355
N37 X-29.566 Y-12.952 Z-21.465
N38 X-29.505 Y-12.966 Z-21.568
N39 X-29.432 Y-12.983 Z-21.663
N40 X-29.349 Y-13.002 Z-21.749
N41 X-29.257 Y-13.024 Z-21.823
N42 X-29.156 Y-13.047 Z-21.885
N43 X-29.049 Y-13.072 Z-21.935
N44 X-28.936 Y-13.098 Z-21.971
N45 X-28.821 Y-13.125 Z-21.993
N46 X-28.703 Y-13.152 Z-22
N47 X-27.729 Y-13.378
N48 G3 X-26.529 Y-12.63 I0.226 J0.974
N49 G1 X-26.516 Y-12.576 F1000
The same code when using a radial tool.
N16 MSG ("; ?????1")
N17 G19
N18 DIAMOF
N19 T3 D1
; champfer d10 radial
N20 SETMS(1)
N22 G94
N23 G55
N25 G0 SPOS[4]=112.497
N26 M108
N27 G90 G0 X46.305 Z-20.192 SPOS[4]=112.497
N28 G1 F5000
N29 X30.357
N30 X29.055
N31 X28.917 Z-20.33
N32 X28.784 Z-20.462
N33 X28.662 Z-20.585
N34 X28.555 Z-20.692
N35 X28.468 Z-20.78
N36 X28.403 Z-20.845
N37 X28.363 Z-20.885
N38 X28.349 Z-20.899
N39 X28.73 SPOS[4]=109.97 F1000      This code is processed by G0. Even when writing in each line G1 and working feed.
N40 X29.091 SPOS[4]=107.127
N41 X29.401 SPOS[4]=104.284
N42 X29.75 SPOS[4]=99.861
N43 X29.91 SPOS[4]=96.527
N44 X29.993 SPOS[4]=93.193
N45 X29.947 SPOS[4]=88.691
N46 X29.749 SPOS[4]=84.19
N47 X29.4 SPOS[4]=79.767
N48 X29.091 SPOS[4]=76.924
N49 X28.73 SPOS[4]=74.081
N50 X28.349 SPOS[4]=71.554
N51 X27.931 SPOS[4]=69.027
If SPOS[4]= is replaced with C4=, then the machine does not process this code and returns an error.
How do I get the correct code? Postprocessor standard from the library https://cam.autodesk.com/hsmposts?p=siemens_mill-turn
Model for example.
Replies (0)
