Centroid post is adding extra T command
pocolypz
pocolypz
Attached is the G code posted from Fusion 360 for our Centroid CNC router with a tool changer. The post processor is adding a T command for a different tool after it instructs a tool change. This is odd, and I can't find a setting in Fusion 360 that would cause this to happen. Obviously this affects tool height compensation and Z height accuracy. Please help!
Copy and pasted code/issue from line 132 - 135 in attached G code file:
(2D Pocket2 (2))
N645 M1
N650 T1 M6
N655 T5
Sq_14
Hey there, if T5 would be the next tool to use, i'd think "Preload Tool" is active in you POST Options. The T5 after the M6 (which actually commands a tool change of the tool in the spindle) should not affect the tool offsets.
If T5 isn't in use at all, there's more serious problem in your post.
