Biesse Rover B 3.35 FT Post Processor
Message 1 of 1
Hello all,
I'm looking for a post processor for a Biesse Rover B 3.35 FT I just acquired.  Form what Biesse support has told me the machine operates from a .ISO post.  And the Biesse CIX Router and Biesse Materia CL posts will not work for my machine.  I found out that ArtCAM had a post for my machine.  But it is a .CON file and will not work with Fusion 360.  Here is the .CON file I found.
; G - Code configuration file - with Arc Support
; History
; Who When What
; TM 13/05/99 Written
; BEM 20/05/99 Removed line numbers
; BEM 21/03/00 Added DESCRIPTION and FILE_EXTENSION fields
; BEM 19/06/01 Added support for circular arc output
; move to home pos at end instead of 0,0,ZH
; bem 07/09/01 Added G17 to define plane for circular arcs
; tm 01/08/03 Configured for Biesse Rover 24 with TC
; sc 04/19/04 Configured for Biesse Rover 24
; Origin must be in top left corner
; jvg 17/03/08 edited form BiesseRover24_gcode_arc_mm.con with help from Biesse.
; *Biesse has confirmed this post will run CNI control XP600, NC1000, XNC
; Which include Biesse Rover A, B, and C and some older Rover's*
; Must adjust tool description name in tool database to match tools at machine
; jvg 10/07/08 changed PRF=20 which outputs -20, PRF is incremental value from top of block
; rest of code is absolute
; part must be zeroed top left corner, Z zero at table BOTTOM
; pah 18/03/11 Use TOOL_DB_DESC as tool description...it is the user defined description in the tool database
DESCRIPTION = "Biesse Klever - XP600 (mm) (*.ISO*)"
FILE_EXTENSION = "ISO"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 1
LINE_NUM_INCREMENT = 1
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|@|F|1.0|0.001]
FORMAT = [FP|@||1.0|0.001]
FORMAT = [FC|@||1.0|0.001]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3|-1]
FORMAT = [Z|#|Z|1.3|-1]
;FORMAT = [ZI|#|Z|1.3|-1]
; Arc Centre Cordinates
FORMAT = [IA|@|I|1.3]
FORMAT = [JA|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3|-1]
FORMAT = [ZH|@|Z|1.3|-1]
; 91 = ASCII for [
; 13 10 = ASCII for Carriage return
; 93 = ASCII for ]
; 34 = ASCII for "
START = "[91]COMMENTO[93]"
;START = "[FILENAME]"
;START = "[13][10]"
START = "[91]CENTRO01[93]"
;[13][10]"
START = "PARAMETRI=000000000"
START = "UTENSILI=000000000"
START = "LABELF=000000000"
START = "LABELC=000000000"
START = "FORATURA=000000000"
START = "CONTORNATURA=000000000"
START = "TABELLEFORI=000000000"
START = "CONFASSIST=000000000"
START = "ATTREZZAGGIO=000000000"
;[13][10]"
; Setup Material parameters
START = "[91]PARAMETRI01[93]"
START = "N10 G71 HC=1 LY=[YSIZE] PLPZ=[ZMATERIAL] PDM=0 PUOS=0 FIL=0 BLO=0 ACC=0 RUO=1 PRS=1 PRL=1 PPWQ=0.000 KA=256.000 LZ=[ZMATERIAL] LX=[XSIZE] "
START = "%"
START = "[91]UTENSILI01[93]"
START = "%"
START = "[91]CONTORNATURA01[93]"
; Set up program header and tool
START = "[N] PAN=1 ST1=[34][TOOL_DB_DESC][34] ST2=[34]NULL[34] ST3=[34]NULL[34] L=PCUA "
START = "[N] QX=0 QY=0 ST2=[34]NULL[34] PRKZ=1 PG40=40 ST1=[34]1[34] PRF=-20 VF=[FP] F=[FC] ST3=[34]NULL[34] L=PON"
START = "[N] WL(PRWL)=2 WL(PRWL+1)=0 M28"
START = "[N] WL(PRWL)=3 WF(PRWL+1)=2 M24"
; Program moves
RAPID_RATE_MOVE = "[N] G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "[N] G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[N] [X] [Y] [Z]"
FIRST_CW_ARC_MOVE = "[N] G5 [X] [Y] R-[Radius] [F]"
CW_ARC_MOVE = "[N] G5 [X] [Y] R-[Radius]"
FIRST_CCW_ARC_MOVE = "[N] G4 [X] [Y] R[Radius] [F]"
CCW_ARC_MOVE = "[N] G4 [X] [Y] R[Radius]"
; G4 CCW Radius + End point
; G5 CW Radius + End point
; G7 + G8 Elipse
TOOLCHANGE = "[N] L=POFF"
TOOLCHANGE = "[N] PAN=1 ST1=[34][TOOL_DB_DESC][34] ST2=[34]NULL[34] ST3=[34]NULL[34] L=PCUA"
TOOLCHANGE = "[N] QX=0 QY=0 ST2=[34]NULL[34] PRKZ=1 PG40=40 ST1=[34]1[34] PRF=-20 VF=[FP] F=[FC] ST3=[34]NULL[34] L=PON"
TOOLCHANGE = "[N] WL(PRWL)=2 WL(PRWL+1)=0 M28"
TOOLCHANGE = "[N] WL(PRWL)=3 WF(PRWL+1)=2 M24"
; End of file
END = "[N] WL(PRWL)=3 WF(PRWL+1)=1 M24"
END = "[N] WL(PRWL)=2 WL(PRWL+1)=0 M28"
END = "[N] WL(PRWL)=1 WF(PRWL+1)=0 M24"
END = "[N] L=POFF"
END = "%"
; Load an Auxiliary DLL to postprocess file after output ...
;AUX_DLL = "aux_dlls\biesse.dll"
;AUX_DLL_DATA = "OUTPUT_TOOLS"
I am also attaching the programing manual to this forum and the .zip file I found the .CON post in.
Thanks for the help.
Replies (0)
