B axis with tilted mounting point
sislana
sislana
I am having a trouble configuring post processor for 5 axis machine with 5 axis head, where A axis rotates arround Z axis, while B axis mounting point is tilted. Machine is Maka HC 57R. I am attaching a photo.
for example in axis definition like this:
var bAxis = createAxis({coordinate:0, table:true, axis:[0, 1, 0], range:[-360,360], preference:1});
I can't see where I could specify this angle at which axis is attached.
I would need this post for Mach4, which doesn't support TCP or any other advanced 5 axis features.
Thank you
serge.quiblier
Hi @sislana
It's in the axis definition, by modifying the axis:[0, 1, 0] definition.
That current definition means the axis is rotating around the Y axis.
If it's a 45 degrees compound angle, then the definition should be:
axis:[0, 0.70710678, 0.70710678],
If it's another angle, use the value for the sine and cosine of that angle instead.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
sislana
Thanks @serge.quiblier ,
this was fast and exactly the explanation I needed.
There is a thing that causes me some troubles. A axis revolves arround Z axis, but if set axis:0,0,1 there will be no output from post processor. But If I define it as axis:1,0,0, there is output.
This is how I defined A and B axis, and on attached picture, offsets can be seen:
var aAxis = createAxis({coordinate:0, table:false, axis:[0,0,1], offset:[-0.3,149.84,0], range:[-280,30], cyclic:false, preference:0, tcp:useTCP});
var bAxis = createAxis({coordinate:1, table:false, axis:[0,0.766672327695,0.64203858291067], offset:[0,0,0], range:[-280,30], cyclic:false, preference:0, tcp:useTCP});
    machineConfiguration = new MachineConfiguration(aAxis, bAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // map tip mode
Would my definitions make any sense?
serge.quiblier
Hi @sislana
You definition need to be slightly improved.
As I don't want to guide you through modifying the post, in twenty different places, the easiest will be that one:7
The kinematic definition and the axis output are related thru the coordinates variable.
It is driven by the three lines like that one:
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.disable();
What we will do is defining your first axis as an axis rotating aroung Z, or else the c Axis.
var aAxis = createAxis({coordinate:2, table:false, axis:[0,0,1], offset:[-0.3,149.84,0], range:[-280,30], cyclic:false, preference:0, tcp:useTCP});
    optimizeMachineAngles2(3); // optimize for head head machine
I changed two elements, the coordinate for the aAxis definition, and the optimizeMachineAngles2, as your machine does NOT support RTCP, and it's a head / head configuration.
Then we need to change the prefix for the axis, as the cOutput variable will be using a C prefix, but this aggregate is not managing a C axis, but an A axis. (Not respecting the usual axis denomination)
We have to edit that line, near the beginning of the file:
var cOutput = createVariable({prefix:"A"}, abcFormat);  // changing the prefix to A
Regards
Serge.Q
cam.autodesk.com
