Allow hiding Build-In Properties
Can we find a way to hide the Built-In Parameters?
This is pretty valuable UI "Real Estate" and, quite frankly, I can never recall changing these on-the-fly. They are basically set and forget for 99.999% of users, so why devote in-your-face space to them? Man Very Happy
Else, move them to the Machine Definition where we can set once and then completely forget about them?
I would second this.
Laurens-3DTechDraw
For out lathe's we do change the highfeedrate some times. Since highfeed is quicker for repositioning in milling mode.
But the rest is a set and forget indeed.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
It would be nice to have as an option. As a user, I only want to see what I have to see. Screen clutter is evil.
Instead of classifying these as Built-In variables, why not just allow them to be standard javascript var?
Laurens-3DTechDraw
Because the post API needs them I believe.
Laurens Wijnschenk
3DTechDraw
timdrink01
Does anyone know if it's possible to control the order of the properties.  It seems that posts with the property allow3DArcs it displays ahead of the built-in properties but I haven't been able to sort out why.
Laurens-3DTechDraw
I believe they are sorted Alphabetically and I believe the B from Built-in cause them to be next.
Laurens Wijnschenk
3DTechDraw
