Adding an Axis for coolant dosing to post processor
Max.Borhof
Max.Borhof
On my CNC I use a stepper motor peristaltic pump to dose the coolant in a Fogbuster-style minimal lubrication system. Until now, the stepper is driven by an external controller with a potentiometer to manually adjust the speed of the stepper motor. While it makes coolant dosing more reliable than the original Fogbuster, I still have to constantly adjust the stepper speed for different tools and their respective cutting speeds.
In a first step, I would like to add another axis to my CNC-controller to drive the peristaltic pump. My goal is to regulate the amount of dispensed coolant via Gcode.
I was hoping for the G-Code wizards to lend a hand or point me in the right direction.
Right now I am using an almost unmodified version of the Autodesk Reprap Postprocessor
thePostmaster
What's does the line of code that controls the flow look like? It should be pretty straight forward to add in a line that references the feed speed. Could be done at every feed speed change.
Max.Borhof
@thePostmaster
Referencing the feed speed is a great idea!
For now, I have just set up an additional Axis W for the pump motor. I can easily adjust the coolant flow by changing the steps per millimeter for the W Axis on the controller side. So for example if I command the W-Axis to move 100mm (G1 W100) it would dispense 100ml of coolant.
So a straight cut in X+ direction would look something like this:
G1 X100 W2000 F2000
It would be nice if the W-axis is only progressed on feed moves (G1, G2 and G3) moves and not on rapid moves (G0).
I have already set up a tool change macro that adjusts the steps/mm of the coolant Axis depending on the tool diameter, so that tools with a larger diameter get more coolant than smaller tools.
EDIT: Maybe it would make even more sense to ajust coolant flow depending on the cutting speed of the tool?
Max.Borhof
"Push"
