Hello all,
I got a Problem with 2D-Contour (Inventor HSM & HSMWorks). In my task I' m working on tangential cutting with diamond tools (cutting edge orientated in cutting direction). The problem is that the whole path is broken at the intersection point and thus splitted in two toolpaths (preserve order makes no difference). I need one path which begins at (0/0) and ends at (10/25).
Anyone has a solution for this?
Thanks Stefan
Solved by George-Roberts. Go to Solution.
Do you see the same thing in Inventor HSM And HSMWorks?
Because the selections are totally different, and I can understand this happening in Inventor HSM not so much in HSMWorks.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
HSMWorks and Inventor HSM leads to the same result.
Trace works but unfortionaly lacks in terms of top height, bottom heigt and for me most important finishing passes and configuration... Sure It's possible to use multiple trace steps but therefore one needs to draw also the lines in multiple heights because of the lack of top height adjustment. So it would be really nice to get this with 2D-Contour. The main drawback is that it gives me G1 X Y points for the structure and no more G2/3 commands! That leads in a problem in tangential mode in my controller.
Thanks Stefan
** I've replied this before you edited your post sorry ***
I understand
But with 1 sketch and 2 traces you could probably do everything you need
In trace you can use "Axial offset" to set the height and "Axial offset passes" to set the number and height of passes.
1 trace for rough, 1 trace for finish.
Thanks Stefan
Pretty sure 2D Contour is indeed not allowed to cross itself.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Yes, but this doesn't solve the problem that it doesn't out put G2/3 commands. I only get G1 point to point motion also for the arcs, this leads in bad behavior of the tangential mode and would lead to damage on the tools.
Also with smoothing on?
Laurens Wijnschenk
3DTechDraw
René for Legend.
I believe trace does linearise a lot of moves... I have just drawn up a similar shape and can see your issue. I have found an option which may be a 'workaround', as long as you have the 3D machining strategies.
First off, create a 'dummy' block below the sketch, it can be any size bigger than the sketch
Create a 'Project' toolpath, select the contours to machine and enable smoothing.
Your post should give G2/G3 moves with this strategy 🙂
It would be good if the trace command could output G2/G3 as it would be a much cleaner solution
That's the solution! Thanks! It works in HSMworks and Inventor HSM, perfect!
