2.5 axis controller , how to make cam only move in 2 axis per command line
zebb.guy
zebb.guy
Hi is there a way to make fusion 360 manufacture only move 2 axis at the same time for older controllers?
for example, i can use parallel but then i have to set direction to one way in passes
otherwise i will actually do 3d machining which is what i have selected but I'm trying to avoid.
is there anyway apart from what im already doing to only move 2 axis at the same time in the command line ?
so rather than trying to move x y and z it will only move two axis per line ?
serge.quiblier
Hi @zebb.guy
there is no automatic way to do this in Fusion.
As you have already found, the only way to achieve this is to manually set the parameters to avoid helical plunge,
Try to select unidirection toolpath, i.e parallel unidirectionnal and so on.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
florianD8LYR
I'm a beginner with modding PPs - just curious if my idea would suite to this issue??
just for example the linear motion, because its easy to change..
lets say you start with this code
here is the PP part that is in charge of that NC code output
and you break it up into two lines of code like that,
you end up with this code output,
that would at least help @zebb.guy so his machine only moves with X&Y or with Z or I'm wrong on this ?
serge.quiblier
Hi @florianD8LYR
You are wrong.
Ignoring a value, is unsafe, as the tool had to move in this position.
It's better, but surely not simpler, to force the toolpath to move along basic directions.
For example when doing a parallel toolpath, it MUST be along X or Y. And not along exotic angle, 20, 35, 45 degree.
Doing vertical ramp, then a planar lead in and lead out...
Regards
Serge.Q
cam.autodesk.com
florianD8LYR
oh dam* it - now it lights up,..   for sure you are right, because then the machine would first move in XY then in Z and thats a totally different movement
