I would like to be able to turn cutter compensation on above the the part. I often have the situation were my tool diameter is not much smaller than the slot or groove. So I do not have the room to even turn Wear comp on inside the slot. I was able to do it the MasterCAM. Right now I have to manually edit the code, which takes longer than I'd like. I am thinking it could be an option under the Linking tab where you specify the lead in and lead out.
What I want to do is:
- Lead In - turn cutter comp on then move down in the Z
- Lead Out - move up in Z and turn it off
Example program:
