The Project Lead The Way curriculum uses the Lab Volt 5600 CNC mill.
I have received a generic labvolt post processor but we are having many problems with it.
The G&M codes need to include two digits and need to be placed in front of the x y z coordinates or command. For example "M06 7" is the accepted code for tool change to tool #7. "M03 S1000" is correct format for spindle speed but it is not the format generated by the generic Labvolt post processor.
Also LabVolt 5600 does not use M1 to stop before a tool change.
I am having problems with plane changes G18 & G19 plane specifications too.
Labvolt is crashing prior to completing the code unless I manually edit the end of the code.
