Quote from Sandvik:
- When using a ball nose end mill, the most critical area of the cutting edge is the tool centre, where the cutting speed is close to zero, which is unfavorable for the cutting process. Chip evacuation at the tool centre is critical, due to the narrow space at the chisel edge.
- Therefore, tilting the spindle or the workpiece 10 to 15 degrees is recommended, which moves the cutting zone away from the tool centre.
It would be great to have this possibility in every 3D finish operation, that way the multiaxis toolpaths will be even better without creating complex extra operations.
Rob showed a workaround to do something like this in HSMWorks "Flow", but it would be better is this is just in every 3D operation.
