Show only
Search instead for
I would really like some 4 axis toolpaths for roughing and finishing a part with just XZA moves:
This has the following advantages
Gives you the ability to rough cilindrical parts without the need of a lathe
Machining faster then indexed 3D roughing on cilindrical parts
It could be something like this.
I know that HSMWorks has something like this in the form of 4axis sub, but it does not support 360deg rotations and the current toolpath wrapping in Inventor HSM is only wrapped 2D.
I know Inventor has "Wrap tool path" inside the 2D Adaptive, 2D Pocket and 2D Contour operations that allow you to machine around a cylindrical feature and has worked well for me on the 1 part I've needed it for so far, but its far from what I saw in the video. maybe they will develop it further in the future.
I love HSM. However because of the work we are doing at my shop we may need to look for this feature somewhere else. It would be the clear and singular reason why I move to a different software package. 😕
I spoke about this to a few guys at Autodesk University. Its for sure in the works and the help of the Powermill team will improve this, but without a timeline. For now there are some things you can do with Flow toolpath.
Autodesk, pls do this for SolidWorks, this wery helpfull feature. It will help to extend the resource of the cutting edge milling tool, and will reduce the time for milling part. Will be great if the "adaptive" machining function can process a part 360 degrees in one setup. The same function is need for "scallop". HSM most user frendly CAM aplication.
