There are a lot of situations where you want to add extra "custom" information to an operation to use this in the post. If an operation has such a parameter you can let the post output different code:
Some examples to use a parameter:
- Coolant pressure to control a the speed of a spinjet
- Amount of smoothing that the control needs to apply
- Laser power
- Rotation direction preference for 3+2
- Rotation angle of a turning tool (for face turning)
- Retract position after this specific operation
- Anything else you want to tell and operation
ESPRIT shows the custom fields as an extra tab in the operation.
I know you can hack something to use the "notes", but you have to do all kinds of text manipulkations, its prone to error and you can see nowhere if an operation has a a note, so it stays invisable
