Show only
Search instead for
The Baileigh Plasma Table post processor is now available for beta testing. You can download it here. Please provide feedback on any problems you find or any suggestions you may have.
I have a PT22 and am struggling to get the Baileigh Post added into the processor list in the post processor selection. I have downloaded the program from the post library, which is the same one mentioned above. However it's an application file and I can't seem to find the right file to add to the post list. Any way you all can help?
I'm having trouble running the g-code that the fusion 360, Baileigh Plasma generic post processor is generating. The torch is not retracting in the Z axis in between cut moves and the torch flame turns off then back on quickly which causes the work piece to be cut when the torch SHOULD be turning off and retracting in the Z axis before rapid moves. After looking through the g-code it looks like the same line of g-code is being generated twice at the end of each cut move. When I go into the g-code and manually delete the duplicate lines it cuts the way it should with the torch turning off and retracting before rapid moves.
