Using multiple work offsets
ronald.edwards
ronald.edwards
Is there a way to output  the speeds and feeds in the second work offset. When an m01 is read, the second offset loses the speeds Can this be done in HSM or is it a post issue? The result is having to read the beginning of the tool and jump through the program. I am still working on the program but I need to address this issue.  I attached the post I cannot get the pack and go for the part program to send. Thanks
ronald.edwards
I sent the wrong post. I am running this on a Toyoda
Hi @ronald.edwards , I believe it is a post issue.  You might get more help if you post this issue in the post processor forum. Also you may want to add a tool call.
Jason
