User Interface Defaults
jonathan.calkins
jonathan.calkins
Is there a way to change defaults in Inventor like under CAM and the drilling cycle, I always have to select "deep drilling - full retract" and set the pecking depth to 0.100. Other settings like drill through depth and the like, would be nice to have it default to a value determined by the user.
Is there a way to set these default values, like a macro setting adjust? The program has defaults, obviously; it would be nice if there was a way to edit them.
I have searched around and I am not seeming to find exactly what I am looking for. If someone could point me in the right direction, that would be great.
ckautz
Make a file specifically for CAM templates, and make your drilling cycle. Open "Compare and Edit..." and set to your desired value. Then "Store as Template" or "Save Parameters as Default"
jonathan.calkins
Thank you so much. That is exactly what I was looking for.
