Radial Mill in a Turn/Mill center
Hey
I have a part that I have to turn in a Turn / Mill center (4th axle, X, Y, Z, C) where I have to make a chamfer on the end of the part, with a asymmetrical, for I can do it I need a LiveTool that is Radial. I want the Tool to run in the X and C axle
at the same time, but I have not succeeded in finding a way in which I can get HSM to do it.illustration.PNG
in advance thank you for your answer
Laurens-3DTechDraw
Hi Man,
The attached file should work.
Yet I personally would try a back chamfer tool. Probably is faster and creates a better surface finish.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Thank you.
It works like a charm, good idea with back chamfer but I don't have one available right now
maybe I should get one 😉
