Parallel strategy faulty toolpath
m.breurather
Message 1 of 8
m.breurather
Dear HSM community,
in my recent part, I noticed a very strange fault within the parallel toolpath.
When I simulate the toolpath, it looks like this:
F360 simulationF360 simulation
When machining this part, the machine behaved strangely (or so I thought). After checking all settings again, I tried comparing the simulation with NCViewer. This is what I get there:
NCViewer simNCViewer sim
As you can see, the toolpaths clearly do not match. I have a customized post processor for my EMCO ConceptMill 250, which is a HMIOperate type controll. It is based on Autodesk's provided Siemens Sinumerik 840D. Both post processors return the same ncviewer simulation.
What went wrong?
Best,
Moritz
Replies (7)
Message 2 of 8
seth.madore
Can you share the file or at least the g-code?
What flavor of HSM are you using, Fusion, Inventor, HSMWorks?
Seth Madore
Message 3 of 8
m.breurather
Of course - please see attached file.
EDIT: The plattform is Fusion 360, and the forum won't let me upload my .mpf file (gcode). The parallel toolpath is the last in the Setup.
Moritz
Message 4 of 8
lenny_1962
Here is a suggestion.
turn the path 90 degrees you'll get a nicer part and the all the steps are linear.
this may help you get around the current issue until fixed, but still it's a better way IMO.
Message 5 of 8
seth.madore
I agree with @lenny_1962 . However, another suggestion would be to turn off Smoothing. This is what I get with it off:
2019-04-03_10h58_25.pnga
Granted, it's almost 2.25 times the size of code....
I think this is a post process issue. I will raise it with that team and get back to you
Seth Madore
Message 6 of 8
m.breurather
Thank you both for your answers.
The non-smoothing setting fixed the issue - however, my machine is very sensitive to loads of code, so I won't be using that. Instead, the 90 degree variant sounds pracitcal - I will try that.
Thank you!
Moritz
Message 7 of 8
AchimN
Thanks for bringing this to our attention.
I´ve updated all generic siemens posts regarding arcs on non XY planes. The output of your sample file looks now correct. Maybe you have a chance to double check that with the simulation on the control directly.
Achim.N
Principal Technology Consultant
Message 8 of 8
m.breurather
Thanks! Awesome to see that even after such a long time you guys still work on that.
I do no longer have access to the machine, but I may be able to get a Sinumerik simulation software. I will try to check it out.
Best,
Moritz
