Name engraving
Name engraving
Name engraving
I am making a ring that is roughly 19 mm inside diameter and about 10 mm wide. it will be a flat surface.
Have have a VF fourth axis machine to use for the manufacturing of it.
My problem is that i want to engrave a name on the outside surface of the ring but i have little experience with using HSM works to generate tool paths.
i created the model in solid works and then used the text and wrap option to put the text on the ring.
Now I just need some help on how to properly machine the engraving into the ring. I attached a screenshot of the model, but i would like to know how to make it work in all text situations so that i can change styles and whatnot.
Any help is much appreciated!
thanks Matt
Laurens-3DTechDraw
This totally depends on how you would want the letters to be cut out.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
ArjanDijk
Appearantly this is a double post: http://forums.autodesk.com/t5/machining-discussions/name-engraving-on-a-ring/m-p/6831006#M12309
ps: Laurens, I used your video Smiley Happy
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
