Mastercam Tools
Mastercam Tools
Talayoe
Mastercam Tools
Talayoe
Hello all,
I am reasonably new to HSM, so I apologzie if this is a repeat but I couldnt find the answer in a search.
I have been a mastercam user for a long time and have a reasonably extensive tool library. I see in HSM tool library the option to import tools and it has a mastercam option for tools and holders.
I tried the export in mastercam, but when I select HSM to import that text file nothing appears to happen. I would have thot it would throw an error if anything, but nothing.
If anyone has used this feature and has some input, I would greatly appreciate it and not having to spend MANY hours re-inputting all my tools.
Thanks much!
Btw: Mastercam version 2017 and HSM 2017.
-Randy
Inventor 2017 PDS
Laurens-3DTechDraw
What does mastercam output for a file?
I mean HSM is pretty picky about what kind of files it can import.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Talayoe
Mastercam can output what it calls a 'report' and also a 'detailed report'
This is an example of a detailed report
# = 14
Type = Endmill2 Sphere
Tool name = 1/8 BALLNOSE ENDMILL
Diameter = 0.125000
Rad. Type = Full
Cor. rad. = 0.062500
Threads = 0.000000
Tip Angle = 180.000000
Dia. offset number = 14
Length offset number = 14
Feed rate = 10.000000
Plunge rate = 10.000000
Retract rate = 10.000000
Spindle speed = 4500
Number of flutes = 4
% of Matl. SFM = 100.000000
% of Matl. Feed/Tooth = 12.000000
Coolant = Flood
Material = Carbide
Tool filename = C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX7\MILL\TOOLS\SPHERMIL.MCX-7
Required pilot dia. = 0.000000
Length = 0.375000
Overall length = 2.250000
Shoulder length = 0.500000
Shank Diameter = 0.125000
Holder dia. = 2.000000
Holder length = 1.000000
Spindle rotation = CW
Manufacturer's tool code =
Chuck =
Metric Values = No
Rough step XY (%) = 50.000000
Rough step Z (%) = 50.000000
Finish step XY (%) = 25.000000
Finish step Z (%) = 25.000000
This is a report
# Type Diameter Tool Name Cor. rad. Rad. Type
14 Endmill2 Sphere 0.125000 1/8 BALLNOSE ENDMILL 0.062500 Full
20 Drill 0.125000 1/8 OSG S/C DRILL 0.000000 None
The interesting this is that in HSM it give the option for Mastercam .TXT files and this is what is output from Mastercam.
Thanks for the input thus far! 🙂
-Randy
Inventor 2017 PDS
Laurens-3DTechDraw
I think you are exporting each tool and it wants a whole library at once.
Laurens Wijnschenk
3DTechDraw
René for Legend.
