Last week we were making parts without issues.
We did an Inventor 2023 update last week, and now this weekend with the same part, when we re-generate our tool paths Inventor CAM makes a mistake deep down in the g-code and puts the spindle through the part and into the table. This is really bad, like very bad.
I've found an online g-code simulator to illustrate my point.
From our revision control, this is the result of the g-code generation of last Wednesday:
And now as of the latest inventor update, with code generated today, this is the result:
We made a small tweek to the part, but regardless, nothing should cause g-code like this!.
Is there any way we can get some help with this????.
I can send the .ipt file to an Autodesk person, but can't post it here due to NDA.
Thanks.
EDIT:
Actually it looks like a bug.
What we changed was the "Stay Down Level" on the linking tab of an adaptive tool path. We made this change was our machine spending too much time plunging into air.
When we select a 90% stay-down level, we get valid g-code.
When we select "MOST", we get INVALID g-code as posted above.
