Invalid post processor configuration 'C:\Program Files\HSMWorks\posts'.
Hi All ,
When I want to take the setup sheet, I get an error like the one below.
Could you help me , please ?
Regards ,
Mehmet Can Yıldırım
Laurens-3DTechDraw
I think the standard path is not correct for your installation.
Can you try so set the default setup sheet manually?
I made a quick video on how to do this:
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Thank you for your help.Problem solved.But now it does not give a preview of the part. What could be the reason for this?
Mehmet Can Yıldırım
George-Roberts
Is there an image stored in the same folder as the posted setup sheet? For example, if you store the setup sheet on your desktop, there should also be multiple images (I believe .png) which are referenced in the HTML of the setup sheet..
