HSM 2019 tools speeds
elec86
Message 1 of 10
elec86
when I choose a sos HSM 2019 tool the cutting speed remains the same regardless of the tool chosen what's happening?
Replies (9)
Message 2 of 10
lenny_1962
are you talking HSMWorks?
Message 3 of 10
elec86
no hsm 2019 with inventor 2029
Message 4 of 10
kacper.suchomski
Have you changed the speed value in the operations panel?
Kacper Suchomski
Message 5 of 10
elec86
no in adaptive 2d tool ​​when I change tool the cutting speed (rpm min) does not change
Message 6 of 10
kacper.suchomski
I don't quite understand.
  1. Cutting speed is not the same as rotational speed.
  2. Speed parameters are defined in the operations panel.
Kacper Suchomski
Message 7 of 10
elec86
 so Speed parameters are defined  automatic with soft or  with me ?
Message 8 of 10
kacper.suchomski
By user - based on the tool's catalog or leaflet (or experience).
Kacper Suchomski
Message 9 of 10
lenny_1962
First you mean Inventor 2025, correct?
So if you check the AD site on compatibility the only IVCAM that is supported is 2025 for Inventor 2025, that could be the issue that you are using IVCAM 2019...???
Message 10 of 10
elec86
j'utilise  inventor 2019
