HSM 2018 - Editor and Backplot
jeff.pek
Community Manager Community Manager
Message 1 of 42
jeff.pek
Hi all -
We've been watching the feedback regarding the elimination of the backplotting capabilities in the version of the CIMCO Editor that ships with Inventor HSM and HSMWorks. It's clear that this is a capability that many of you are genuinely missing. We'd like to give you a little background on what happened here, and what we're planning to do about it.
For the past few years, we have had a technology sharing agreement in place where we could redistribute the Professional version of the editor, in exchange for access to the HSM CAM kernel. This agreement expired at the end of last year, so we had to renegotiate the arrangement.
The arrangement we reached, at considerable increased cost to Autodesk, was to redistribute only the Standard version of the editor, with a corresponding reseller agreement, where we can provide access to the Pro-level features at an extra cost.
We are considering an amendment to the agreement with CIMCO that would allow us to include the Professional version with certain levels of the Autodesk HSM product. This is still under discussion, and we have no firm plans to do this.
We apologize for the inconvenience, and truly regret that we weren't able to provide advance notice of the change.
We'll keep you posted about what, if any, adjustments we are able to make in this area. As has been noted in various forum posts, those of you with access to prior releases are still able to use the older version of the editor, with backplot capabilities.
Thank you very much for your feedback concerning how much you value the backplot feature.
Best Regards,
  Jeff Pek, Sr. Manager, Autodesk HSM
  Al Whatmough, Product Manager, Autodesk HSM
Replies (41)
Message 41 of 42
denis_q
Message 42 of 42
RodC327
I can upload a file, but I believe the issue is that it will not consider the Mill diameter, only the tip diameter.  If you set it to 0 it will generate forever, if you set it to .002 here is what you get:
The tool path on the left is a drill mill with .002" Tip diameter, the other is a standard .250 mill.
