FUSION 360 TURNING GROVE ISSUE
I have a part that I am CAMing in F360, and I am using turning grove.
I keep getting Kernel CAM error, or something quite similar to that.
IS this an Keyboard Chair interface issue?  AKA: am i doing something wrong?
Thanks for the help guys!
Steinwerks
Your issue seems to stem from confining the toolpath between an edge, and the face that it borders. It's a zero space confinement, and probably screwing with the kernel.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
jeff.walters
N. Stein is correct. You have a .12 wide grooving tool and have a .025 width defined with your containments. If you add .096 to your Backside Stock Offset you will get a tool path.
Jeff Walters
Senior Support Engineer, CAM
