Best feature to use for ID Boring
Trying to interpolate inside a .32" diameter cavity that is .1" deep with a .25" endmill.  No matter how I set the leads in the linking tab of 2D Contour I can't get a toolpath.  I tried Circular but the roughing amount seemed odd and not easily controlled (was going to rough then finish).  Bore seems to be some sort of thread milling?  That posts with just lines of code - I would like to see I and J.
Thanks!
Which post are you using? I get arc moves both with 2D contour with ramp, and Bore, using Haas post. Normally I would use bore for feature like this.
The standard haas killing post
