Show only
Search instead for
I saw a similar problem I think when using the latest development version of Hsmworks. If I have Don't go home selected in a turning point, it sets the retract height very far off the part, not affected by the heights input. If I set the option to Go home at beginning and end, the retract and clearance heights seem to work as expected. Is this what you are seeing?
This is what I see. need to wait until correct this mistake, or use go home or correct the control program manually. Returning home in my case is not optimal.
