HSM Beta Testing (English / Deutsch)
Inventor HSM 2019.2 development release
11 REPLIES 11
Message 1 of 12
balsmen
2347 Views, 11 Replies
Inventor HSM 2019.2 development release is now available at:
https://cam.autodesk.com/download/inventor-hsm-experimental
Please let us know if there are any issues. Thanks.
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
11 REPLIES 11
Message 2 of 12
None of the hotkey/Shortkey's seem to work.
Tried Ctrl+G, Ctrl+D, Ctrl+L
Ctrl+S does seem to work.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 12
Which build of Inventor are you working with?
  Jeff
Message 4 of 12
Not sure what to say. These all work fine for me. You first selected a browser item, right?
  Jeff
Message 5 of 12
  Jeff
It seems to work now after a second Inventor Reboot.Smiley Frustrated
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 6 of 12
@jeff.pek
It's back.
Sending you an email with screencast now.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 7 of 12
Probing operations are no longer shown in simulation.
Message 8 of 12
narzinskin
in reply to: narzinskin
i'm not sure how this is possible, but it appears to be skipping the second writeBlock of all probing cases from my post.  this was working yesterday.  i tried rolling back versions and it is still having the same issue.  any ideas?2018-09-20 11_20_00-Window.png2018-09-20 11_20_21-Autodesk HSM Edit 8.02.27 - [C__Users_narzinskin_AppData_Local_Inventor HSM_nc_O.png
Message 9 of 12
narzinskin
Was cycletype previously in onCyclePoint?
2018-09-20 11_24_35-Autodesk HSM Edit 8.02.27 - [C__Users_narzinskin_AppData_Local_Inventor HSM_nc_O.png
Message 10 of 12
AchimN
Cannot reproduce this issue, it works fine on my end. Maybe you can share your part + post?
Achim.N
Principal Technology Consultant
Message 11 of 12
narzinskin
in reply to: AchimN
It ended up not being the post but the probing operations generated in this development release.  I reverted back to the current release and had to recreate the probing opps..regenerating still produced the issue.  I will share the assembly with the bad probe opps through send feedback.
thanks, Nick
Message 12 of 12
narzinskin
I should have mentioned, regenerating the probe opps in the current release fixed the simulation issue, but they still won't post correctly.  I tried my posts as well as the generic haas  and fanuc with same results.
