HSM Beta Testing (English / Deutsch)
HSMWorks 2017 R3 release candidate
1 REPLY 1
fonsecr
574 Views, 1 Reply
The release candidate for HSMWorks 2017 R3 is now ready. Release HSMWorks 2017 R3 41577.
So unless you find anything critical we will make this public for all soon. We will update HSMXpress as well at that time.
The changes since R2 are:
New in this version:
Added support for thread mill when using thread mill cycle in Drilling strategy. #6479
Added support for tube stock in Job.
Fixed issue where model analysis could fail if model has a bad (degenerate) face for drilling. #6146
Updated list of Solidworks commands that don't need geometry analysis when closed.
Toolpath preview is correct now for patterns with large toolpath. #6159
Fixed wrong calculation of minimum and maximum radial extents for Tube Stock. #6335
Fixed issue with wrong default parameter for Secondary Spindle Chuck, causing the height plane to be offset. #6172
Fixed potential failure when using store as template. #5918
Changes to toolpath generation:
Fixed wrong feed for finishing pass for Turning Profile when using no drag feature. #6440
Fixed retract below clearance radius for ID machining using Turning Profile. #6395
Fixed potential generation failure for Adaptive Clearing for narrow pockets. #5998
Fixed wrong linking for 2D Contour. #3672
Fixed generation failure for Adaptive Clearing. #5954
Fixed wrong retract for Adaptive Clearing. #3251
Fixed fragmented finishing path issue for Turning Profile. #5744
Fixed lead-out outside of allowed area for Turning Profile. #5726
Changes to post processor:
Added support for subprograms for Fanuc post.
Added support for IJK when using G73/G83 for Fadal post.
Added support for IJK when using G73/G83 for next generation HAAS post.
Added property 'writeCuttingModes' to output colors used for laser cutting for Universal Laser DXF post.
Added support for IJK when using G73/G83 for HAAS post.
General improvements and simplification of HAAS DS-30y post.
Major update of multi-axis support for HURCO post.
Added support for controlling G61/G64 smoothing using property 'useSmoothing' for UCCNC post.
Added more information for circular moves for Dump post.
Improved rotary axis clamp handling for HAAS posts.
Turn off coolant on tool change for Mitsubishi turning post.
Added warning when using work offset 0 with non-zero work offsets at the same time for common ISO posts.
Only allow up to 90deg sweeps for G2/G3 moves when using R-word (radius) instead of IJK-words (center) to avoid problems on some CNCs where the center could potentially drift significantly for a correct NC program and hence result in wrong machining. The problem can be exposed when cutting around 180deg arcs on some CNCs. If a particular CNC does not have a such a problem the post can be customized to allow bigger arcs. IJK-mode remains unchanged and is recommended over using R-word.
Added spindle stop and M0 at tool change for UCCNC posts.
Changed maximum sweep to 90deg for circular motion for Datron post for improved part quality.
Changed post to use IJK for G2/G3 instead of R for better part quality.
Limit circular motion to maximum 90deg for improved part quality.
Changed HAAS post to use IJK for G2/G3 instead of R for better part quality.
Force G95 for tapping for Fanuc post.
Updated tool definition for CAMPlete APT post.
Updated tool support for CAMPlete APT post.
Only output G69 when G68 is active for HAAS posts.
Added new property 'SB3v36' to control tool changes for Shopbot OpenSBP post.
Added 'spindleDirectionCode' property to control spindle M-codes for Shopbot ISO post.
Fixed parametric feed support when using feed per revolution for turning posts.
Fixed tapping support for UCCNC post.
Fixed support for tapping cycles and dwell for UCCNC posts.
Fixed various mill-turn issues like C-axis output for HAAS DS-30Y post.
Fixed potential post failure for Siemens mill-turn post.
Fixed potential error when using parametric feed.
Fixed wrong code for Tormach Turning (Slant-PRO) post.
Fixed inverse time support for Tormach post.
Fixed missing G94/G95 after G96/G97 issue for Siemens mill-turn post.
Fixed failure when using setup sheet.
Fixed failure for driling for Fanuc turning post.
René Fonseca
Software Architect
1 REPLY 1
fonsecr
in reply to: fonsecr
HSMWorks 2017 R3 just went live on hsmworks.com. Download should be available in Autodesk Portal by Monday.
René Fonseca
Software Architect
