Hey guys,
How do we get to the development builds for HSMWorks and Inventor HSM now?
http://cam.autodesk.com/download/HSMWorks is still live if I type in that URL, but I don't see a way to navigate there anymore.
http://cam.autodesk.com/download/Inventor-HSM-PRO is broken. and so is http://cam.autodesk.com/download/inventor-hsm/
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I finished a quick prototype of how this would look if we used the forums:
http://forums.autodesk.com/t5/hsmworks-development-builds/bd-p/348
A few things to keep in mind:
The advantages are:
Please check it out, and let us know your thoughts and/or concerns.
I really love this Idea.
It provides one go to place for the HSM user. (http://forums.autodesk.com/t5/hsm/ct-p/213 that link will provide all you need)
Easy to keep engaged with everything and join the development. It open and engaging, so to speak.
Also it's really nice that users can respond. Now I find myself downloading, finding an issue. Making a thread. See people make a thread about the same issue in the same release somewhere else.
"Now you respond I found this installation problem, anyone else have this?" "If found if you do this it works"
"Warning massive issue with ........., could cause a crash"
This makes the development release more valuable because you could easily see if issue's were found in it.
And last but not least it's easy to go between different releases. Sometimes needed if an issue arises or if you want to compare things between releases.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Scott Moyse
Al, you've listed what the advantages are for using this method. Which we know Laurens is all for :-). But I'm curious if you see any disadvantages to it compared to using the Autodesk beta portal all the other Autodesk products use?
Scott Moyse
Understand the question, but he probably can't answer that here.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Why not? It's a pros and cons discussion about this system here in the public forum surely? There are some issues that would be nice to surmount. I've raised a couple in my reply further up this thread.
Scott Moyse
We can, of course, discuss the con's.
But personally, I don't see many.
I mean getting lost in a thread is always possible.
Also here on the normal forum, so while it might be possible I think we can easily split those replies that shouldn't be there out to their own topic. That way it's not lost for the poster, he actually get's a topic in the correct place where everybody is able to help him, and we keep the threads clean.
Having another bug submission list would make things more confusing for me. It's already harder than it was before we moved to the Autodesk system.
So while I would love to see exactly what's going on with my ticket I'm pretty sure the development team hates people refreshing their website to wait till their bug status changes. It also creates false hope for a lot of users I'm sure. It's always something that needs effort from the development side, and it's that effort I personally rather see spent on actually solving stuff.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Scott Moyse
@scottmoyse wrote:
Laurens, you're completely missing my point. Bugs that are reported against a dev build need to be investigated and logged.
So why wouldn't they be?
You can still send in feedback like you do now on a dev build.
But now you can also respond to a specific build on it's download location? Why wouldn't that be seen by the development and be logged?
Usually when I post a problem with a development release on the forum, someone from the team responds the same day.
Laurens Wijnschenk
3DTechDraw
René for Legend.
@al.whatmough what's the intention of allowing people to comment on these dev build download threads? I personally think that's going to cause an issue with people posting their issues on those thread instead of in their own threads which can be managed and tracked correctly via auto escalation to the support team if needed.
My previous comments & thoughts I've offered here have been because I thought this was about more than just where to host the dev build downloads. But also about where to provide feedback & bug reports about them. Participating in new feature / beta discussions and surveys etc. It seems, based on conversations with Laurens outside of this thread, that isn't the case at all and I've misunderstood the intention.
So my opinion is this, hosting just the dev build download links in the way proposed is perfectly ok. But I think those threads should be Read-Only, and only Autodesk staff can comment on them... so sharing a notice with other users, that there is a significant issue with that build.
Scott Moyse
Al,
Just an added twist...
Some users (very few?) are in the Inventor Beta program. Most of the time it is not an issue as we're testing new features/improvements in isolation. But in late stage beta, we need to use the software for actual work (this is a request from Inventor team). If that beta won't work with Inventor HSM addin then we're outta' luck unless previous versions of Inventor can read newer version designs or have to export to neutral format and loose all design info.
In addition, there is the problem of 'Who do you call?' when a problem comes up - Inventor devs or HSM devs ??
I assume that addressing this issue (if warranted) would best happen in the Autodesk beta area, hence my adding to the mix. Thanks.
Fred
