I tested the Betamode with the new Machine-Configuration. I used one of the given machines.
But when I want to recalculate the operations or make a new one then HSM crashes instantly.
Is this function not for use and just implemented for future projects?
Version:
Inventor 2019 x64 Build: 139 - 02/15/2018
HSM Premium 2019 - 6.1.2.15078
Solved by meletis.stathis. Go to Solution.
Hi @meletis.stathis,
is there a new Version? I just installed 2019 yesterday. Is this then the newest version? I can't find some updates.
My Co-Worker has exactly the same crash ...
Its with any file and with any selected machine. I made a new machine and write all parameters in it.
I have a dumpdata.zip - don't know it helps you.
please try to download the latest Inventor HSM version from Inventor HSM Development versions
and let me know if you still encounter the crashes.
I've tried this and now it works. I don't tested the dev version.
Thank you for your help!
