For 2D adaptive rest machining to be useful, i believe we will need previous tool's 'minimum cutting radius' and 'stock to leave' values. See this example...Without this info taken into context, it over-engages on the first pass and plunges through material on the stepdown. Since this operation is primarily used for roughing, i think this will pose a problem more often than not without these added.
Currently an issue with the forum that doesn't seem to allow 90% of the file formats.
Can you zip it? That is supposed to still work.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
