Program crashes all the time
Hello Everyone,
I just recently started learning Autodesk Helius Composites. When i tried to select material for sandwich analysis program crashed with no error message. Later i clean installed windows 10 hoping errors would disappear but it did not work either. I selected material with some trick but this time when i tried to simulatation it crashed again. I am currently using Helius Composite 2016. I installed hotfix 1 today but it did not work either. What should i do ? Thanks in advance.
david.veinbergs
Hello bayraktar.okan
My first suggestion would be to try Helius Composite 2017. Could you share the material file that causes the crash?
David Veinbergs
I have installed Helius 2017 previously but same problem was present. I tried to select T700 Epoxy and 1025 Steel as materials.
david.veinbergs
I apologize for the delay in response. Are you attempting to select Lamina materials for the sandwich analysis? You should only be able to select a Laminate for the faces and core types from the pull down menu in the Sandwich Geometry tab. Neither of the materials you specified should be available in the sandwich analysis unless they are part of a Laminate.
David Veinbergs
I tried again by starting with creating a new item. I clicked on new laminate, I clicked add to add a new lamina and I selected the material and again and again program just closed itself with no notification, no error message etc.
I have this issue on every time. I cannot create a new laminate. Because of this reason:
Object of type 'System.String' cannot be converted to type 'System.Guid'.
at System.RuntimeType.TryChangeType(Object value, Binder binder, CultureInfo culture, Boolean needsSpecialCast)
at System.RuntimeType.CheckValue(Object value, Binder binder, CultureInfo culture, BindingFlags invokeAttr)
at System.Reflection.MethodBase.CheckArguments(Object[] parameters, Binder binder, BindingFlags invokeAttr, CultureInfo culture, Signature sig)
at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
at ASCD.Material.PopulateFromXml(String xml)
at ASCD.Lamina..ctor(String xml)
at ASCD.DataAccess.GetMaterial(String id, MaterialType materialType, UnitType units)
at ASCD.frmMain.EditObjectFromTree(TreeNode selNode, TagCode tc)
at ASCD.frmMain.contextTree_Edit_Click(Object sender, EventArgs e)
aynı problem bende yaşıyorum çözebildiniz mi
