shader error.
shader error.
chlrh1226
shader error.
chlrh1226
hello, guys.
when i make a entity, shader is not property.
am i miss something?
left is entity that i made, right is original file.
but entity shader is wring.
could you pleases check this with me?
use maya 2024and golaem ver 9.0.2.
i attached the file.
thanks
alexandre_pillon
Hi
Sorry not behind a computer with Maya so I cannot check the scene, but are you using a specific type of shader? In this case it could work at render time, but not in the viewport.
Are the shaders ok when you render?
Else, did you try removing all shaders and  importing your lookdev character again?
See the shading FAQ for more details: https://help.autodesk.com/view/GOLM/ENU/?guid=glm_shading-faq
nicolas_chaverou
Hey there
Just tried on my side with the file you provided but can not reproduce
Please check for errors in the Script Editor maybe
2025-08-04 08_05_46-Crowd_woman360cam04_rig_for_glm.mb_ - Autodesk MAYA 2024.2_ C__Users_chaverou_Do.jpg
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
