[Release] New Golaem Release Announcements
alexandre_pillon
Community Manager Community Manager
alexandre_pillon
You will find below the release notes of each new version of Golaem
Subscribe to the topic using the options menu to be warned about each version
alexandre_pillon
Golaem 9.0 Beta (2023/11/10)
New Features
  • New Animation Engine which supports translation, orientation and scale animations
  • FBX, USDSkel, BVH and Golaem Cache files can now be used directly as Motion Clips in Golaem Behaviors
  • New Crowd Level paradigm which allows to recreate a simulation context from a Golaem Cache node
  • New PlayAnimation Layer in the Layout Tool to allow motion replacement at layout time
  • Modular rigs can now be imported in Golaem (with some limitations)
  • New TrackLocator node to define a curve based target mode
  • New Follow Track mode in the Goto Behavior
  • New LOD and Geometry Tag definition in the Character Maker via LOD Level and Geometry Tag labels
Improvements
  • IF Operator triggers are now consistent when a Behavior is disconnected
  • Default LOD Levels for a Mesh Asset are read from a custom attribute glmLodLevels when imported in the Character Maker
  • Default Geometry Tags for a Mesh Asset are read from a custom attribute glmGeometryTag when imported in the Character Maker
  • Entity meshes and materials are now instanced when using the USD Skel Bake Export
  • Materials are not overriden anymore if already exported when using the USD Skel Bake Export
  • USDA is now available on Linux when using the USD Skel Bake Export
  • Character Geometry Files can be exported per LOD or Geometry Tag in the Character Node
  • Behavior Container can be shared on multiple Entity Types in the Behavior Editor
  • Golaem Attributes can be created on multiple Entity Types in the Behavior Editor
  • New Output Channel "None" in the ChOpOutput node
  • New Channel Operator Behavior "outputChannel" Channel
  • New Locomotion Behavior "motionClipBlendWeight", "startMotionBlendWeight" Channels
  • New Physics Collision Filter attributes in the Entity Type Node
  • New Entity Voxels display option in the Entity Visual Feedback
  • Improved voxel definition and accuracy on Entities and External Entities
  • Added multithread support to the Mesh Render Previz display mode
  • Motion Mapping files can now be created from a Golaem Character File
  • Simplified Skeleton Mapping for new characters when not using Motion Retargeting
Bug fixes
  • Fixed scrolling in the Excluded Mesh Asset Panels of the Character Maker
Refactoring
  • Refactored Goto Behavior Attribute Editor
  • Refactored ChopInput Attribute Editor
  • Refactored TextScrollList controls
  • Character Files and Shading Namespaces attributes are now unlocked in the Crowd Manager Node
  • Added submenus for the Terrain Locator, EntityType Node and Target Locator in the Golaem Shelf
  • Removed the Golaemisator icon for the Golaem Shelf
  • Refactored Golaem Qt Windows names
API
  • New glmImportCacheAsSim command
  • New setAllNodesOfTypeAttribute function in the Layout Python API
Supported DCCs
  • Autodesk Maya 2020, 2022, 2023, 2024
  • Autodesk 3ds Max 2020, 2022, 2023
  • Foundry Katana 3.X, 4.X, 5.X, 6.X
  • Unreal Engine 4.27, 5.1, 5.2
  • SideFx Houdini 19.0.622, 19.5.435
Supported Rendering Engines
  • Arnold - Mtoa 5.2.X, 5.1.X / KtoA 4.1 / Arnold 7.1.X
  • V-Ray - For Maya 5.0.22, 5.1, 5.2 / For 3ds Max 5.1
  • Renderman - For Maya 24.X, 25.X / For Katana 24.X, 25.X
  • Redshift - For Maya 3.0.46-57 / For Katana 3.0.46-57 / For 3ds Max 3.0.46-57
  • USD - Standalone 0.23.08 / For Houdini 19 and 19.5 / For Katana 3.5
  • Guerilla Render 2.1, 2.2, 2.3
Also supported (but must be manually installed):
  • Arnold - Mtoa 5.3 / Ktoa 4.2 / Arnold 7.2
  • V-Ray - For Maya 6.0X, 6.1X / For 3ds Max 6.0X, 6.1X
  • Renderman - For Maya 23.X / For Katana 23.X
  • Redshift - For Maya 3.5.14-16 / For Katana 3.5.14-16
alexandre_pillon
Golaem 9.0.1 (2024/03/07)
New Features
  • New CreateEntity Layer in the Layout Tool to allow creation of characters at layout time
Improvements
  • Added Ground Offset Adaptation Mode in the PlayMotion Layer of the Layout Tool
  • Added Ramp control in the Distance Trigger
  • Added support for animated scales when using modular rigs
  • Added support for Arnold renderer attributes when baking Simulation Caches in UsdProc
  • Added support for Arnold renderer attributes when baking Simulation Caches in UsdSkel
  • Added LOD level on the tree view of the Mesh Asset in the Character Maker
  • Added orientation support when creating a Population Tool from particles
  • Improved performances when manipulating complex Character Files
  • Improved Character Geometry export when blendshapes had no target mesh in the scene
  • Improved the position of the default exit of the IF Behavior Operator
  • Improved Skeleton Automap in the Character Maker
  • Traffic safety distance is in Golaem Unit instead of a percentage of the length
Bug fixes
  • Fixed import of Behavior Templates when using Simulation Levels
  • Fixed incorrect exported rgbPP attribute when using Simulation Levels
  • Fixed Population Tool not being displayed when using Simulation Levels
  • Fixed export of multiple CrowdFields when using Simulation Levels
  • Fixed Group Entity Type display when using Simulation Levels
  • Fixed a crash when using the Motion Collection node
  • Fixed a crash when creating a Simulation Level in certain conditions
  • Fixed a crash when loading a motion with no selection in the Character Maker
  • Fixed a crash when using the SetBone Behavior and the Channel Operator SetBone mode
  • Fixed a crash when reloading a scene with the Simulation Exporter Window open
  • Fixed a crash when loading multiple FBX motion files
  • Fixed a crash when using the SetMeshAsset Layer and the Character File is not accessible
  • Fixed a crash in the Behavior Editor when using broken behavior graphs
  • Fixed support of scale when using modular rigs
  • Fixed motion blending when using stand and locomotion animations at the same time
  • Fixed deletion of the Layout File in a Simulation Cache Proxy node
  • Fixed body mask computation when using usd/fbx/bvh motion files
  • Fixed Character geometry export when using blendshapes in local origin
  • Fixed normal computation in the Golaem Character Geometry file
  • Fixed Visual Feedback Entity Voxels not working when no Sensors were selected
  • Fixed Layout computation when changing the name of the Simulation Cache
  • Fixed Body Mask with Blind Data using usd/fbx/bvh motion files
  • Fixed a drift in orientation when using usd/fbx/bvh motion files
  • Fixed PlayAnimation layout node was not keeping the skeleton overrides values
  • Fixed AdaptGround Behavior Attribute Editor
  • Fixed MotionCollection Attribute Editor
Refactoring
  • Added support for Houdini 20.0
  • Removed support for Houdini 19.0
  • Added support for USD 0.23.11
  • Added support for MayaUSD 0.23.0 - 0.27.0
  • Removed support for USD 0.23.08
  • Added submenus for the Target Locator in the Golaem Shelf
Supported DCCs
  • Autodesk 3ds Max 2022, 2023, 2024
  • Unreal Engine 4.27, 5.2, 5.3
  • SideFx Houdini 19.5.716, 20.0.506
  • USD - Standalone 0.23.11 / For MayaUSD 0.23.0 - 0.27.0 / For Houdini 19.5 and 20.0 / For Katana 3.5
nicolas_chaverou
Golaem 9.1.1 (2024/08/01)
Improvements
  • Weighted Asset Group nodes distribution can now be controlled using Golaem Attributes
  • Multiple motion files can be played in the PlayMotion Layer of the Layout Tool
  • Added access to the Mesh Asset Assignment window in the SetMeshAsset Layer of the Layout Tool
  • Added Apply button in the Entity Mesh Asset Assignment window
  • Added Highlight Factor attribute used when selecting an Entity in Simulation or Cache Replay mode
  • Selection outline can be disabled during simulation and cache replay
  • Rigid bodies can now be disabled in the Physics Override node of the Character Maker
  • Added a menu entry to add a selected Golaem node to the current level
  • Added an option to select entities inside meshes in the Entity Selector Layer
  • Added display mask options on the CrowdCachePosture Layer of the Layout Tool
  • Added display mask options on the CrowdCacheRig Layer of the Layout Tool
  • Added an option to disable bone-to-bone replay mapping on the Locomotion behavior
  • Disable bone-to-bone replay mapping when using a mirrored animation in Motion and Locomotion behaviors
  • Added a External Maya Field threshold attribute in the Crowd Manager
Bug fixes
  • Fixed a crash when initializing a simulation from particles with a lifespan set to 0
  • Fixed brush position when using the Population Tool Free Place mode for Maya < 2024
  • Fixed rotateNoise not taken into account in the Rotate Layer of the Layout Tool
  • Fixed first slot invalid position in the Population Tool Free Place mode
  • Fixed Population Tool Entity Type and Rendering Type randomness
  • Fixed bones excluded from IK in the IK Behavior
  • Fixed Mesh Render Previz not using existing materials
API
  • Added -getEntitiesIdsInMesh flag in the glmLayoutTool command
Supported DCCs
  • SideFx Houdini 19.5.716, 20.0.688
  • Arnold Mtoa 5.4.X / KtoA 4.2 / Arnold 7.3.X
  • V-Ray For Maya 6.0X, 6.1X / For 3ds Max 6.0X, 6.1X
  • Renderman For Maya 25.X, 24.X / For Katana 25.X, 24.X
  • Redshift For Maya 3.0.46-57 / For Katana 3.0.46-57 / For 3ds Max 3.0.46-57
  • USD Standalone 0.23.11 / For MayaUSD 0.23.0 0.27.0 / For Houdini 19.5 and 20.0 / For Katana 3.5
  • Arnold Mtoa 5.3 / Ktoa 4.2 / Arnold 7.2
  • V-Ray For Maya 6.2X / For 3ds Max 6.2X
  • Renderman For Maya 23.X / For Katana 23.X
  • Redshift For Maya 3.5.14-16 / For Katana 3.5.14-16
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
nicolas_chaverou
Golaem 9.2 (2025/03/26)
Important notice
Golaem Lite features do not require a license anymore, only simulation does
Golaem Personal Learning Edition has been replaced by Autodesk 30 days evaluation
Improvements
  • Added orientation support in the IK Behavior
  • Added multi values comparison in the CurrentFrame, Expression, Texture and Painted Zone Triggers
  • Added group relative lookAt attribute in the Population Tool
  • Added reset slot positions in the Population Tool free place mode
  • Restored Entity Type weights in the Group Entity Type Node
  • Added a scale parameter in the Cloth Behavior
  • Added skinned weights Alembic support in the Golaem Fur Cache file
  • Added an execution order attribute in the MassSpring Behavior.
  • Added Body Mask Attributes for bones and blind data in the PlayAnimation Layer of the Layout Tool
  • Added a Snap Mode in the SnapTool Layer of the Layout Tool
  • Added support of Locomotion Behavior when using the Traffic Behaviors
  • Added more decimals for scalar values in the Layout Tool
  • Added shortcuts to change text, size, color in the Behavior Editor Notes
  • Behavior Editor Notes can be moved with their content
  • Matrices are now blended smoothly when used in Blind Data
  • Added custom framerate override on the GolaemCache Node in the Golaem For Unreal plugin
Bug fixes
  • Fixed Simulation Exporter load settings
  • Fixed ChOp Input type detection bug
  • Fixed ChOp expression when not empty
  • Fixed Rigid Body creation error messages
  • Fixed Motion Blur when using temporal AA in the Golaem For Unreal plugin
  • Fixed Sequence Frame Range in the Golaem For Unreal plugin
  • Fixed Population Tool placement when using traffic curves and the Crowd Unit
  • Fixed EntityType refresh in the Population Tool
  • Fixed Rendering Type color in the Population Tool Free Place mode
  • Fixed slow Population Tool refresh when using colliders with many potential slots
  • Fixed orientation and orientation noise in Component Mode in the Population Tool
  • Fixed orientation when lookAt is enabled in the Population Tool
  • Fixed a crash when editing slots in the Population Tool free place mode
  • Fixed a crash when opening the Layout Tool invalid entities in cache
  • Fixed a crash when appending different Population Tools to the same particle system
  • Fixed a crash when using more than 9 entityTypes and MasterSlave Behavior
  • Fixed a crash when running a simulation with an empty If Behavior Operator
  • Fixed a crash when using SetGeometryFile Layer in the USDProc plugin
  • Fixed exploding postures when using series of LookAt Layers in the Layout Tool
  • Fixed SetRenderingType Layer with Shading Node Attributes in the Layout Tool
  • Fixed TimeOffset Layer with Shading Node Attributes in the Layout Tool
  • Fixed blind data replay in the PlayAnimation Layer of the Layout Tool
  • Fixed ReplaceLODDistances Layer in the Layout Tool
  • Fixed Layout Tool frame range in Layout Nodes
  • Fixed Simulation Cache Library loading in Python 3
  • Fixed GCG Import in Maya
  • Fixed entityKilled flag in the glmSimCacheTool command
  • Fixed FBX Motion Clip animation replay (_rootHeightUnscaled error message)
  • Fixed steering angle when overtaking in the Traffic Behavior
  • Fixed naming conflicts when using the Character Maker Locator shapes
  • Fixed append producing an additional crowdField
Refactoring
  • Added Autodesk licensing
  • Added support for Maya 2026
  • Added support for Maya 2025
  • Added support for Unreal Engine 5.4
  • Added support for Houdini 20.0.688 linux gcc11
  • Added support Arnold 7.4 / MtoA 5.5 in Maya 2026
  • Added support for Redshift 3.6.0
  • Removed Golaem RLM licensing
  • Removed support for Maya 2020
  • Removed support for Unreal Engine 5.2
  • Removed support for Redshift 3.0.46
  • Refactored Advanced Attributes in Motion & Locomotion
  • Blind data are now read by default in Locomotion Behavior
  • Refactored the Character Maker default Display
  • Removed Weight Attribute in the MassSpring Behavior
API
  • Added a lodName flag in the glmExportCharacterGeometry command
  • Added glmEntityIds flag in the USD procedural plugin syntax
Supported DCCs
  • Autodesk Maya 2022, 2023, 2024, 2025, 2026
  • Unreal Engine 4.27, 5.3, 5.4
  • Arnold - Mtoa 5.4.X / KtoA 4.2 / Arnold 7.3.X & Mtoa 5.5.X for Maya 2026
  • Renderman - For Maya 25.X, 24.X / For Katana 25.X, 24.X
  • Redshift - For Maya 3.6.0-1 / For Katana 3.6.0-1 / For 3ds Max 3.6.0-1
  • V-Ray - For Maya 6.2X / For 3ds Max 6.2X
NICOLAS CHAVEROU
