Importing scale in Unreal
josevidosavfx
Observer Observer
josevidosavfx
Observer
Observer
Hello, I'm currently exporting a cache from Golaem, but when I import it into Unreal, it appears oversized. I'm fairly new to Golaem, so any advice would be appreciated.
nicolas_chaverou
Hey there,
Please check the Golaem For Unreal FAQ here:
https://help.autodesk.com/view/GOLM/ENU/?guid=glm_golaem-for-unreal-faq
Especially the following entry:
Characters are not at the right scale and / or flicker when replayed in the viewport
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
william_bobant4TQVJ
Observer
Observer
Heya,
Sorry, I'm stuck at the same thing and I'm a bit confused: the doc states one needs to enter the following env variable:
:: Set Scene Unit (0 for millimeters, 1 for centimeters, 3 for meters, 4 for inches, 5 for feet)
set GLMCROWD_UNIT=3
But I can't find the right place to do so, as everything I do ends up with the same result in Unreal. Is it a Windows env variable? An Unreal Engine's? Something else?
Thanks!
josevidosavfx
Observer
Observer
Hi William, I tried the same thing as you without success. Finally, I used meters in Golaem to get it working correctly in Unreal. Remember to rescale your environment correctly once imported into Maya. I'm sorry I can't help you more.
If anyone has a better solution, please share it. 🙂
william_bobant4TQVJ
Observer
Observer
Hey!
thanks for the heads-up! Sadly in this case I was already in meters 😞 I could always lower down the scale even more to match Unreal's but I'm sure there's a better and easier way to proceed
nicolas_chaverou
The cleanest way is to use a launcher script / app to start a DCC
On my side I have a script (.bat) where i set a couple of env vars in before launching UE/Maya/Houdini... including the Unit and other things
This allows to be non invasive in my system and contain the environment variable to the execution of the DCC (when I close the DCC the envvar is removed)
Here's a sample of my script for UE
set GLMCROWD_UNIT=3
set UNREAL_LOCATION=C:\Program Files\Epic Games\UE_%UNREAL_VERSION%\
set UNREAL_EXE=Engine\Binaries\Win64\UnrealEditor.exe
::Launch
"%UNREAL_LOCATION%\%UNREAL_EXE%" "%GLM_INSTALL_PREFIX%\%GLM_PROJECT%"
NICOLAS CHAVEROU
