can i get a entity velocities value on visual feedback?
chlrh1226
chlrh1226
hello,
i wondering can i get a entity velocities value on visual feedback?
i use this value like trigger to change motion behavior.
i plan to use that value on express trigger or, chop behavior etc.
can i get this value? or other velocity value. not vector value.
if you guys any idea., please let me know. Thanks.
nicolas_chaverou
Hey there,
Can you please specify Golaem and Maya version ?
Depending on the answer, you can probably use the Channel entityVelocity
Vector will be cast as float in the Expression Trigger
https://help.autodesk.com/view/GOLM/ENU/?guid=glm_channels
Hope that helps
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
chlrh1226
hello, Thank you for your replying.
i use golaem version 9.0.2 and maya version 2024.
i make a entity attribute for take a entity velocity
and get a entity velocity value on chop behavior.
but they get only vector value for entity velocity.
i want to get a entity velocity value on visual feedback.
how can i translate entity velocity vector value to float value?
or is there other want to get a entity velocity value on visual feedback?
my goal is use like this
depending on entity velocity, entity will change they motion behavior
Thank you for your help.
nicolas_chaverou
If you make the attribute a float, the norm of the vector will be written in the attribute
Else you can use the norm operator in the ChOp Operation node
NICOLAS CHAVEROU
chlrh1226
awesome!!!
good advice for me!
thanks!
