How to structure Hubs and Projects
jlogan208
jlogan208
I think I've been looking at Hubs and structuring hubs wrong but want to see how others are setting them up.
I have 4 departments who use Fusion. So, I created a separate Hub for each department and a Test Hub. My thinking was, each department would have a hub/project/assets with roles and permissions set accordingly. I did this to avoid crossing streams between departments and users.
I am an administrator in each Hub. However, now I can't seem to create any new Hubs, and need to.
Should I have created one company Hub and then Department Project folders or something in that vein?
J. Logan
CAD Administrator >AutoDesk Products, Windows 11
akshay_kakade
Hello @jlogan208
Greeting !
You're absolutely right to revisit your Hub structure.
Good recommend is to be setting up
one company Hub and organizing your departments as separate projects within that Hub. This approach simplifies user management, avoids Hub creation limits, and still allows you to control access via project-level roles and permissions.
You can find the full setup guide here:
How to Set Up Autodesk Fusion Hub
Thanks and Regards,
Akshay Kakade
