How To Delete Fusion Team
Message 1 of 27
How do delete a fusion team?
This question is repeated many a times.
I request the community legends to answer this issue.
Replies (26)
Message 21 of 27
FrodoZhou
You can follow these steps to delete your Autodesk account which will delete all your data associated with that account essentially. https://www.autodesk.com/support/account/manage/use/delete
However, if you want to keep your account while only delete teams, this is the best info for you.
Delete a team
Currently, you can't delete a team from your account in Team Settings. Instead, the primary admin should move all subscriptions to a different team. Then contact Autodesk Support to remove the team.
Frodo
Message 22 of 27
mauricio_olmedo
I find that to be a terrible solution. In fact, I don't think that is a solution at all.
Is there anyplace where we can suggest, or vote for the suggestion, to implement a change and allow us to delete a fusion team without deleting our accounts?
Message 23 of 27
dejot30
Log in to your fusion team account, look for and switch to individual, I wanted to take a screenshot where you should switch but this FTM account doesn't work for me anymore. Good luck.
Message 24 of 27
mauricio_olmedo
Thank you. By doing so, will I then be able to create a new fusion team? Or will I still be blocked and have to invite my coworkers manually to every project?
Message 25 of 27
SBoener3BBCE
Did anyone find a way to delete a team where you are the only member if you accidentally created one?
Message 26 of 27
mauricio_olmedo
I had to send a ticket to customer support asking them to erase the team for me. After some emails back and forth they were able to help me. I wasn't able to do it myself, which I still think is a bummer.
Message 27 of 27
FrodoZhou
Hi, for anyone who wants to request to remove your autodesk account can you please try this link?
https://accounts.autodesk.com/externaluser/delete
